Hello Dan--
Old Town 148512 is a 17 foot CS (common sense, or middle) grade HW model canoe that was completed April-June of 1947. It has red Western cedar planking, open spruce gunwales, and ash decks, thwarts, and seat frames. It was fitted with a keel and painted dark green, then shipped to Minneapolis, MN, on April 25, 1949.
Does it have cane seats or slatted ones? I ask because it seems to me that in 1947 Old Town hadn't re-established their cane supply, but by '49 they should have been able to put in their standard cane seats (which by then consisted of machine-made sheet cane, fit into a groove on the hardwood frame). So, the canoe might have been finished with wartime slatted seats in '47, which were swapped-out when the cane appeared again. Most build records don't specify slatted seats, even if the canoe had slatted seats. I believe the cane supply dried up for all canoe builders in about 1943 and lasted until about 1947.
Is the canoe still in Minneapolis? I ask because that's my ol' hometown.
The scan of this record is attached below-- click on it to get a larger image. This scan and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at
http://www.wcha.org/ot_records/ if you want more details. I hope that you and anyone else reading this will join or renew membership in the WCHA so that services like this can continue. See
http://www.wcha.org/wcha/ to learn more about the WCHA and
http://www.wcha.org/join.php to renew.
