Old Town #142885
kmartin
Hi
I am finishing off a war years canoe and would like the build info. Old Town #142885
Thanks, Kevin
The Old Town canoe with serial number 142885 is a 16 foot long, CS (common sense or middle) grade, HW (heavy water) model with red western cedar planking, open spruce gunwales, ash decks, ash thwarts, ash seats, and a keel. It was built between October and December, 1945. The original exterior paint color was dark green. It shipped on December 31st, 1945 to Point Pleasant, New Jersey. The back side of the card indicates that it had moved to Hooksett, New Hampshire by June of 1978 when there was a previous request for a copy of this build record. Scans showing both sides of this build record can be found by following the links at the attached thumbnail images below.
These scans and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/catalogs/old-town/records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-wcha to learn more about the WCHA and http://www.wcha.org/store/membership to join.
It is also possible that you could have another number or manufacturer if this description doesn't match your canoe. Feel free to reply here if you have any other questions. Thanks,
