Welcome, the Old Town canoe with serial number 121096 is a 16 foot long, CS (Common Sense or middle) grade, HW (heavy water) model with open spruce gunwales, oak decks, oak thwarts, oak seats, and a keel. It was built between March and June, 1937. The original exterior paint color was dark Yale blue. It shipped on June 21st, 1937 to Metamora, Michigan. The back side of the scan indicates that it may not have moved far by October of 1977 when there was a previous request for a copy of this build record. Scans showing both sides of this build record can be found by following the links at the attached thumbnail images below.
These scans and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at http://www.wcha.org/catalogs/old-town/records/ if you want more details. I hope that you will contribute, join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-wcha to learn more about the WCHA and http://www.wcha.org/store/membership to join.
