Hello - and a deck question
SCE
Hello, I’m a new poster, long-time lurker.
I’ve been restoring an OT 50-Pounder (#126211 - 13). To this point I’ve been able to get questions answered by searching this forum — there is a wealth of experience here, and folks are really good about giving helpful answers. I do have a deck-building question that I couldn’t find a 100% answer for, though:
Q: do you cut the new decks out and bevel the sides before steam-bending, or after?
Background:
Both decks are dry-rotted, so I’m building new out of 3/4 ash. The decks curve up by 1/4” along the last 4 1/2” of length to the point, and they are also domed by about 1/8” from the sides to the centerline. The sides are beveled by about 6 to 8 degrees. Does the cutting and beveling happen before or after steam-bending?
Of course I could be over-thinking this…
Sven
No judgement here. Been building a workshop for about 2 years and scavenging canoes for a few years. 16 to date. Folks here are the right folks to ask. Do share....
Sure…
These are the “before” pictures. Since then it’s been stripped and disassembled. I’m armed with saws and I think I know how to use them…
You didn't ask but there are at least 2 methods used to get the curves on decks,
1 - bend them (the more elegant IMO)
2 - cut them from a thicker piece of stock
and finally as for final cutting - either before or after bending?
Joe Seliga learned long ago to bend 1st and cut/shape after bending.
Thanks Dan, that’s what I was looking for.
I’ll be steam bending the decks - working on the molds next week.
A bit of bevel on the decks consists of a few strokes with a plane. Either before or after works. I'd do it after with a spoke shave. I also would likely carve the deck instead of bending.
  • Like
Reactions: SCE
Agree with the guys… bend first, then install the deck. Then carve it to meet the gunwales.
I’d start with an angle grinder and 40 grit. Then a belt sander with 60 grit, then a random sander for the final fit. And maybe you don’t even need to be that aggressive if you only have a 1/4” to remove.
As I often say, “leave it fat, and sneak up on it”.
In a much longer deck wit a lot of rise, I used a chain saw to rough it in once!
Generally, Old Town canoes with 16”, or 20” decks, I purchase them from Island Falls Canoe. They are bent correctly on original Old Town forms.
That sounds a bit like Bill Miller removing fiberglass with an axe. :D
