I am restoring an 18' OT Guide. I have read numerous posts on scarf joints, but am still having difficulties with them. Following are the steps I have taken.
-I am replacing inwales with ash. They have been steam bent (still a bit of spring back) and dried.
-I have cut 10-12" scarf joints and sanded flat. The mating surfaces match well. If it was previously glued and failed, I sanded down to wood before gluing a second time.
-I have tried two types of adhesive: System Three 5 min. epoxy and Titebond III, both recently purchased. Both have failed (epoxy at least 2 times).
- applied well mixed epoxy to both sides, then clamped with 3-4 clamps for 3-6 hours. With Titebond, I coated both sides, let get tacky and clamped for 8 hours. Both cases have squeeze out once clamped.
-I glued the inwale on a flat table (as opposed to clamping and installing in the canoe)
-For the epoxy, I clamped the glued inwale to the canoe ribs from 4-8 hours after the initial glue up, figuring the joint had cured. For Titebond, I clamped them in place 24 hours after initial glue up.
-Both the epoxy and Titebond joints failed after 4-24 hours.
- I have another one in process with epoxy. Coated both surfaces even more liberally and will not unclamp or move them for 24 hours. I will then clamp them to the canoe and cross my fingers!
-The Stelmok and Thurlow book (pg. 171) shows a 9-10" scarf joint with two screws (from the out facing side of the inwale). I want to avoid screws, but will do it if necessary. If it is, anyone know what a good screw size is?
-I also have inwale ends to scarf glue on once I get them laid out and cut to join the stem and deck. They are about 3' long and also have well cut scarf joints from 10-12". I am now worried about these scarfs not gluing well as there seems to be more stress on this joint due to horizontal and vertical bending.
WHAT am I doing wrong? Should I be gluing while the inwale is clamped to the canoe (ribs)?
