Brad Koeneman
Maker of fine kindling
I am nearly completing the stripping process of my fifth stripper, but this is my first experience with bead & cove strips. My difficulty is in making a tight joint at the centerline as I move away from the stems. Unlike square or beveled strips, the bead and cove does not allow me to fit the strip tightly at the end so that I may scribe a line to which I can cut. I am guesstimating each strip and not satisfied with the results. I have tried stripping one side ahead of the other, cutting the centerline, then fitting the other side, as well as doing each side simultaneously, but still can't achieve the nice tight fit I could with square or beveled strips. If I had my way I would switch back to square strips having made the turn of the bilge but I have already milled all of my stock for bead & cove. 100 % clear Alaskan Yellow Cedar in 20' lengths, and enough for two canoes! I had better figure out how to do this! Anyone have any pointers for me?
