I have been attempting to strip the varnish from a 1950's vintage Chestnut, which has proved to be very difficult. I do not see evidence of multiple coats, so am guessing this is the original varnish. About 70% of the inside of the hull was still covered, which looks shiny and is hard, when I started this project. I've tried using my last can of DCM-containing stripper which is not highly effective, and have tried Citrus Strip, which is slightly more effective if I wait for an hour or so before scraping. I've tried both on the same spot. I've been over most of the hull 3 times now and still some areas have varnish. The hull has been washed with hot, soapy water and a stiff bristle brush, and with TSP solution, yet spots of varnish remain. The edges of the ribs are a particular problem. It looks like I will be spending many, many hours sanding unless someone has a trick for getting this varnish off. Does anyone know what formulation of varnish Chestnut was using near the end of their life? Are there tricks other than the usual strippers for getting rid of this varnish? Tom McCloud
