Build record
pathologist
I'm requesting the build record for an available canoe, advertised as a 1941(?) OT, 16ft. with sailing rig, #130560.
Thanks, Pathologist
The Old Town canoe with serial number 130560 is a 16 foot long, CS (Common Sense or middle) grade, Yankee model with open spruce gunwales, a keel, and a middle thwart. It was built between August and December, 1940. The original exterior paint color was dark green. It was shipped on April 19th, 1941 to Springfield, Illinois. A scan of this build record can be found by following the link at the attached thumbnail image below.
It is also possible that you could have another number or manufacturer if this description don't match your canoe. The sail rig is not mentioned on the build record so that was probably added after it left the factory. Feel free to reply here if you have any other questions.
Mr. Gray,
Thanks much for the rapid reply regarding my request for the build record and above all your interest in such things.
thanks much, Pathologist
