In June of 2003 I recanvased and filled my Otca. After spending four weeks curing in a hot garage, I applied the first two coats of paint to the Otca. Then, the Otca sat in another garage until June of this year, when I applied the final coat of paint and subsequently took the canoe on a twelve day trip in the Quetico. On about day four or five of the trip, the canoe began to develop a number of blisters - most much smaller than a centimeter in diameter. The blisters were filled with some sort of solvent. When the blisters were popped, the filler was exposed, which leads me to believe that the filler was not fully cured when I painted the Otca. Does that sound correct?
How long should I have waited for the filler to cure? (It no longer gave off the "curing odor" prior to the application of the first and second coats.)
Were the blisters caused by exposure to the sun or by exposure to the water?
Will the paint continue to blister or can I assume that the filler has fully cured by now?
Will I damage the canoe if I continue to paddle it in this condition?
What is the suggested method of repair?
Thank you,
Jesse
Thank you,
Jesse
