Tim the Inspector
Kayakaholic
...and if so, did you break it like I did to mine?  Twice?
So I'm not the most muscular guy out there but it seems I may be stronger than I thought. I've over-torqued a couple of bolts in the hold-down mechanism and it looks like I'm going to have to do some repairing/replacing. The part that I buggered up is essentially a channel with maybe 1/8" tabs on one end to hold in a square nut. When I over-tightened the bolt that runs through this nut, I've managed to partially pull the tabs open and partially pull the channel open, causing the nut to pull its way out of captivity. This has happened before, I squeezed the channel shut last time and hammered the tabs back over but it seems the problem has returned.
Has anyone else ever dealt with this before? I think I have a good idea for how to fix this once and for all but before I do I thought I'd ask for opinions.
-Tim
-Tim
