17 Foot Old Town Serial # 129454-17
Walter Hallman
My neighbor just had an estate sale and I have a new winter project. It’s a 17 Foot Old Town (from what I can tell from my research). The serial number is 129454-17. It looks like he started the restoration but stopped. The canvas is sanded down and if it was varnished the interior it is now stripped and ready for refinishing after a general cleaning. The keel was removed and is missing. From looking at the hull it came equipped with a floor rack, a step for a mast, and there are shadows screw holes from sponsons. The seats were removed (there are mounting holes). There is a little rot in the bow and strength but overall the wood is in excellent shape.
My plan is to accomplish a complete restoration. Strip canvas, replace damaged wood, install new canvas, replace interior seating, and of course paint the hull. I ordered the book “The Wood and Canvas Canoe” and it is an excellent book but one can never have enough reference material. What other books are recommended?
I understand there is a source for the build sheets for Old Town canoes. If possible I would appreciate more information on this particular canoe.
I agree with Paul, 129454 - 17. This makes it about a 1940 canoe. What is all that white stuff on the hull? Looks structurally sound. Will be a nice canoe when done. Don't sweat the sponsons - many restorers leave them off. Keel is not necessary. You can build seats without much trouble, and in 1940 pressed cane was in use. TM..
Welcome and congratulations, the Old Town canoe with serial number 1294540 is a 17 foot long, AA (or top) grade, HW (heavy water) model with open mahogany gunwales, mahogany decks, mahogany thwarts, mahogany seats, a keel, outside stems, a floor rack, sponsons, and painter rings on the bow and stern. It was built between February, 1940 and December, 1941. The original exterior paint color was similar to the one shown at http://www.wcha.org/catalogs/old-town/designs/design10.gif which was known as the design. It shipped on December 15th, 1941 to Baltimore, Maryland. A scan of this build record can be found below.
It is also possible that you could have another number or manufacturer this description doesn't match the canoe. See https://www.wcha.org/forums/index.php?attachments/31525/ for another canoe that shipped to the same place. Feel free to reply if you have any other questions.
Thanks for the quick reply. That description matches everything on my boat. The color scheme looks very nice and I will recreate that as part of the restoration. Thank you for this service.
This is not the first canoe I've seen which was shipped to Bacharach Rasin, Baltimore, but I don't know what business they were in. Canoes often do not move far from their shipping destination. If it is still in eastern MD, there is a very active wooden canoe group at the watermans museum in Northeast. If you have questions, that's the place to get answers. TM...
Yes, the stems and keel are also missing. There was a brass stem piece in the canoe. Did they normally come with brass in 1940? Although I like they looks of the steamed wood on the ends.
If the outside end of the internal stem looks broad, like 1/2", then it had an external wooden stem. You can bend oak and replace a missing one. I would think brass for stembands was still available in early 1940, so if there was one laying in the canoe, then it most likely is the original.
They were an outdoor and sporting goods store founded in 1904 according to the information at http://www.baltimoresun.com/news/bs-xpm-1992-02-17-9213001507-story.html but I'm not sure how this relates to rasins.
Yes, brass stem bands would have been standard in 1940 as Tom mentioned and specified at http://www.wcha.org/catalogs/old-town/specific.gif from a period catalog.
Your canoe did have wooden external stems, as per the build record. Those stems would have been protected by a bang plate or stem band. Here is a larger picture of our 1922 OT Ideal (built to the same AA grade specs as your canoe), which is to say, mahogany gunwales, seats, decks, and thwarts. The material of stems and keels is not usually indicated on the build records.
The exterior stems join the keel, and the stem bands run onto the keel for a short distance past the point where the exterior stem meets the keel, except in some cases, where the brass of the stem bands would run the whole length of the keel as well, an extra cost option that would be noted on the build record.
I am not certain of what wood is used in our exterior stems and keel because of varnish and perhaps some stain -- but it appears to be the same mahogany as elsewhere on the canoe. The exterior stems of the yellow 50 Pounder behind the Ideal in the photo above are painted, but having been stripped for restoration, are clearly oak, and the wood looks quite different than that of the Ideal's stems.
