mmmalmberg
I know I saw this mentioned in a thread not long ago but am not finding it.
While canvassing my OTCA I detected a slight difference in the amount of concavity on one side of each end vs the other side. When tacking the canvas along the decks, I was unable to pull it hard enough to bring it completely flat against the planking in that area, and the canvas is floating a good 1/16" off the planking for half a square foot or maybe a bit more.
My first thought was "close enough" and I finished up along the stems and trimmed canvas along the stem tacks. Then it was bugging me and seemed like it might have gotten a bit worse, so I re-pulled and re-stapled those areas. With the canvas stretcher I was able to pull it tight enough to just eliminate this, but after stapling it pulled back enough that it was still floating. I think the problem is too much tension lengthwise, as the concavity runs along the length while vertically it's flat.
I couldn't loosen the canvas at the stems since they were already trimmed, so I re-stretched/re-tacked again but same result, so I went ahead and filled about 4-5 days ago.
I'm worried this could make the canvas more vulnerable to a tear at some point against a rock or whatever. Should I be worried? Any suggestions? Blech.
I guess I didn't make that as quick as I intended
