Keel Dimensions
The Morris that I am looking at is a later Morris I believe. It has white oak outside stems and an ash keel as far as I can tell. The canoe has possibly been recanvassed at some point, so it is possible the keel is a replacement. If it is, it was done very well, so I tend to doubt it. I have not removed the keel yet to see if it has a cove for bedding compound.
The dimensions are: 7/8's inches wide at the base of the keel against the canoe hull. The keel is 5/8's inches high, and the bottom of the keel is 1/2 inch wide. There is a slight taper in the keel to meet the end of the outside stem. It tapers from 7/8's to 5/8's in 14 inches at each end. The keel is butt jointed against the ends of the outside stem. I did not notice a taper in the thickness of the keel when meeting the outside stem. If you need photos or additional information, just shout.
I have a Morris with the original keel, but I can't easily get to it at this point. The canoe is also a later Morris and it is on the To Do list. If I see any differing dimensions in the next month or so I will reply.
Cheers,
Fitz
