Another possible source:
Rawhide Lace & Lacing for Drums | Centralia Fur & Hide (furandhide.com)
- It needs to be soaked a few hours before weaving.
- but not more than a few hours as it really starts to smell awful if left soaking past the point where it has become soft, limp and workable.
- It has a right (smooth) side, which should be the surface you sit on. The rougher side is the back side of the strip.
- Since the lace comes in assorted lengths you often need to splice it to itself. This is done by cutting a small (maybe 3/8" long) lengthwise slit in each piece near its end and threading each piece through the slit of its mating piece. Position splices in spots where you will not be sitting on them.
- It's a good idea to let it dry for several days after lacing. Then go over it with your hand, looking for sharp edges. They can be abrasive to your pants (seriously). Any you find which are really sharp can be eased a bit with fine sandpaper before the seats are varnished.
- Varnish both the frames and the lacing. It is even possible, if desired, to varnish the frames before lacing and then also after lacing. A good spar varnish is generally used for varnishing rawhide-laced products. Varnish them well, as that's what helps to keep the rawhide from sagging and stretching in use.
Honestly, for long distance tripping the most comfortable seat (either rawhide or caned) that I have ever used was topped with a hunk of 1/2" thick ensolite foam (cut up Yoga Mat from some place like Target) wrapped in canvas and tied to the seat frame. For short trips, it's no big deal, but for long trips it can be a lot more comfortable, as well as being usable in camp when you're tired of sitting on rocks and logs.
