Hi,
Back again with a correct number. Took a small brass brush to clean off the paint a little, then holding a flashlight down low with raking angle light we got the correct number: 146528 18. If someone can post a copy of the build sheet that would be awesome, but even the basic grade and materials used would be great. I'm guessing it's a CS grade but I don't know. Another question: what separates the different grades? Is it only what I would call the 'trim'--decks, thwarts, inwales and gunwales? I see the the CS grades typically used red cedar planking. From my experience WRC is quite brittle, and from what I read, white cedar is more flexible. Why would you even use red cedar for planking then, is it the availability of WRC in longer, clear lengths over white cedar? I'll be removing the fiberglas, replacing the decks, thwarts, inwales and gunwales anyway, so this is an opportunity to restore it to a 'higher than original' grade--if that's kosher. But I'm not crazy about WRC for planking. I've worked with it a lot and it's definitely brittle. Any experience and thoughts are appreciated.
Jonathan
Jonathan
