148567-16
The Old Town with serial number 148567 is a 16 foot long, CS (Common Sense or middle) grade, HW (heavy water) model with red western cedar planking, open spruce gunwales, a keel, and outside stems. It was built between April and June, 1947. The original exterior paint was dark green. It shipped on June 27th, 1947 to Mentone, Alabama. A scan showing this build record can be found by following the link at the attached thumbnail image below.
This scan and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to renew.
