112598-16
The Old Town canoe with serial number 112598 is a 16 foot long, AA (or top) grade, HW (Heavy Water) model with red western cedar planking, open mahogany gunwales, mahogany decks, mahogany thwarts, mahogany seats, a keel, and a floor rack. It was built between May and July, 1933. The original exterior paint was dark green. It shipped on July 29th, 1933 to Mast Hope in Pike County, Penna. The back side of the record indicates that it may have moved to Denver, Colorado by 1992 and 1992 when there was a previous request for a copy of this build record. Scans showing both sides of this build record can be found by following the links at the attached thumbnail images below.
These scans and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to renew.
