WoodNCanvas
A book I ran across in my local public library is Stories From The Bow Seat: The Wisdom & Waggery of Canoe Tripping by Don Standfield and Liz Lundell….this is a fine collection of thoughts, tales, interviews, stories, and quotes related to canoes and canoe tripping….I really loved Don Standfield’s interview of two canoe builders, Jack Hurley and Jim Spencer (who now operate their own individual companies but at the time of the interview were building together)….especially this remark from Jack Hurley on the difference between wood canvas canoes and those made from aluminum, Fiberglas or Kevlar:
Going down a river or crossing a lake in anything but wood-canvas is like floating on a linoleum rug. That’s just how it looks when you glance inside one of those types of canoes and watch the bottom flex and shimmer with the water. Whereas, in any wood-canvas canoe you have all these beautiful rich colors of the cedar planking and ribs, hardwood gunwales and decks, and caned seats. Even the smells are nice and directly relate to the environment you are traveling through.
Jim Spencer adds later on:
I suppose there would always be an argument for the different types of materials and canoe designs, but the wood-canvas canoe is one generation away from the birchbark canoe and was made for working and transporting people through the wilderness. It was designed and made out of materials that would stand up to miles and miles of flatwater and whitewater and portaging through very rugged and unexplored terrain. As a trip leader with kids and adults, I have safely traveled across many lakes in a wood-canvas canoe in conditions where other experienced paddlers in the new-design boats were either windbound or took on water during the crossings.
I really liked the following recipe provided by Don Standfield from this same book:
STEAMED CEDAR WITH CANVAS
An elegant accompaniment to fish.
Make ahead of time for relaxed visit with friends.
51 board feet of peeled and deveined eastern white cedar
10 board feet of combined ash, black cherry, and maple
2600 brass tacks
18 feet of 10 weight canvas
¾ gallon of oil base filler
3 quarts of varnish
2 quarts of paint
Assortment of beer to taste (chilled if possible)
Using a large shop, prepare all ingredients the night before. Early the next day preheat element to high heat. Bring an adequate quantity of water in a large pot to a tumbling boil. Steam ribs until al dente (flexible) and bend immediately while still tender. Let stand at room temperature to blend flavors until cool. Chop cleaned white parts of planking into long thin slices, (smaller pieces will fall to ground). Add bulk of brass tacks and planks at random until ribs disappear (careful not to tenderize planking with pounding of tacks). When ingredients become solid remove from mold and set aside. Prepare gunwales and decks by chopping fresh hardwoods. Snip to length and desired shape, introducing slowly for best results. Wrap with canvas skin; skewer with tacks along edges, leave middle open. Add both caned seats and center thwart until balanced. Inlay decks for garnish.
Use the same basic recipe for fifteen and seventeen footers. Quantities will vary including concentration of beer.
Well before serving time, press filler firmly onto bottom side of prepared carcass to seal in natural juices and let marinate. Heat entire hull at medium to high sun for about three weeks, covering occasionally, until fully baked. From a separate pot, baste inside with all-purpose varnish to glaze ribs, careful not to drip, and let harden. Repeat occasionally. Meanwhile, whisk and and gently combine, until mixed but not runny, an assortment of fresh paint to color, stirring occasionally as you serve, and dressing the outside lightly from end to end. The condiments blend even better if allowed to stand for several hours until sticky topping hardens. (Careful not to undercook, but do not let baking temperature bubble surface.) Repeat spreading of additional layers on outer crust and again set aside and let stand until hard. Cover and store in a safe spot until needed. Present whole at room temperature, arranged attractively on an adequate bed of water. If desired, garnish with cherry paddles as a starter. Bon voyage. Serves 2 to 3. (Note: Depending on degree of festivities, presentation may be turned into a dip.)
2600 brass tacks
3 quarts of varnish
2 quarts of paint
