Seat and Thwart screw size
Don Sable
I am restoring a 1921 18' CS grade OTCA. I am trying to replace the steel seat and thwart screws. Measuring the screw size I find that they are #12 (.215" Dia) and 22 threads per inch. This is not the present day standard of #12-24UNC thread size. Was the #12-22??? the common screw size in the 1920's when the canoe was built? I will probably replace with 12-24UNC's. Comments?
I can tell you that a Standard was not adopted for screws threads till much latter. I can't remember if it was 50's or 60's. But I want to say it was early 60's. Before that there were many different sizes and thread combo's.
I restored a lot of old wood working machines for my shop and we never tossed old bolts!! You never knew when you would run into a old one that you couldn't pick up locally.
The '21 Otca that I just finished used 12-24 screws and nuts (Jamestown Distributors). I've never found, (not that they don't exist) a 12-22. I worked in the fastener industry for over 30 years and never encountered a 22TPI screw or bolt. Standards for fasteners were developed in earnest and widely practiced by the mid 1800's. That's not saying that some fly by night wasn't turning out 12-22's or out of tolerance 12-24's. Anything is possible there.... but doubtful in my mind. I have found damaged threads that had to be chased with a tap. Often they were broken off below the nut after installation. That serves two purposes. First it removed the extra shank material when a "too long" screw was used. The other thing is that when the screw is broken off it boogers up the threads so that the nut can't work loose.
Thanks for the quick reply. I agree. I think the screws were just manufactured with loose tolerances back in the 1920's. All of the screws on my canoe matched the 22TPI thread gage whereas the 24TPI gage was a slight misfit. I will replace as you did with 12-24UNC screws.
