The Old Town canoe with serial number 140276 is a 15 foot long fifty pound model in CS (Common Sense or the middle) grade with red Western cedar planking, open spruce gunwales, ash decks, ash thwarts, ash seats, and a keel. It was built between June and August, 1944. The original exterior paint color was dark green with a G. S. (Guide's Special) green bottom. It shipped on August 29th, 1944 to Roscommon, Michigan. A scan showing this build record can be found by following the link at the attached thumbnail image below.
This scan and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/catalogs/old-town/records/ if you want more details. I hope that you will contribute, join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-wcha to learn more about the WCHA and http://www.wcha.org/store/membership to renew.
