Nymph Canoe
Fitz
In Memoriam
Introducing my winter project: Nick Schade's Nymph Canoe featured in WoodenBoat Number 199 and 200 in Nov./Dec. 2007 and Jan./Feb 2008. It is a small, lightweight, double paddle canoe. I'm building it for my mother to use during the summer in Maine.
I saw Nick's version at the WoodenBoat Show two years ago and got the urge to try it. His is a 10 ft. version. I decided to stretch mine to 12 feet, which Nick suggests is doable, and see how it goes. Eventually, the cats let me loft it up and here is my progress. I still have to add the stem forms and line everything up. Then I have to decide what wood to build it with.
I have not built a stripper before, so this should be fun. I'll keep you posted.
Progress Report
The form is all done and aligned. The strips are milled. The stems are bent and glued. I used northern white cedar to laminate the inner stems and bent them with hot water. I will likely bend solid ash stems for the outer stems.
I should be doing up the hull soon.
Fitz
Looking great! Keep us posted on the build. One of these days I'm gonna build a canoe that doesn't take an armada of friends to paddle.....looks like a really cool design.
Nymph
Fitz,
What kind of arrangement did you make to remove the forms from the strongback after you finish stripping the canoe?
Norm
Form Removal
Very good question!!
I have thought of this though. The tumblehome is gonna hang up. The only way to do it is to remove/unscrew each station (this will be a chore) and flip it off the strong back. I have used masking tape along the edge of each station so the glue will stick less. From what I know, I may need a rubber mallet to remove the stations from the hull.
Nymph
When Todd Bradshaw and I were building strippers, we bolted the forms all the way through the strongback, instead of screwing them down to the strongback. When we were done stripping, sanding, and glassing, we could flip it over and unbolt the strongback easily.
You're right, then you need some gentle taps from a rubber mallet to free each of the forms from the strips. But if you've masked the forms well, the glue should not stick to the forms and they pop right out. It's an anti-magical moment, going from the beauty of the sanded and finished exterior to the horrors of the unfinished interior.
Norm
Access
Thanks Norm. I am going to take one more look at the forms and make sure I have access to remove them when the hull is stripped up. The box beam is hollow, so I may be able to get in there and bolt the forms on for easier access.
Fitz.
Access
Bolts are a lot easier than trying to remove screws that are upside down, underneath a strongback, and that you can't see. And, of course, one or five of those screws will strip...
Thanks for posting the link to the John McPhee interview. He's one of the best literary journalists of all time. I know him and I've written about him quite a lot in my career as a college professor. As you see in the interview, talking to McPhee is about the same as reading him. His voice in print is the same as his voice in person.
Norm
May I humbly suggest using "packing tape" rather than masking tape?
Glue might stick pretty well to the masking tape, especially where it manages to get through staple holes (if you're using them).
Tape
Rob:
I kinda used the terms "masking tape" generically. It is actually the green 3M high tack tape. I have seen other folks use it on the form and I plan to use it elsewhere in the project, so it is what I had on hand.
Cheers,
Fitz
We've discovered that we like to use the fiberglass-reinforced packing tape. Masking tape is OK, but tears when staples are removed and can lead to the boat sticking to the forms a bit when you're 'glassing. Plain packing tape suffers from the same issue. The stuff with the lines of fiberglass running through it seems to be much better.
Lay it carefully to avoid wrinkles!
Stripping
Well, after a hiatus of sorts, I got a few strips on today. The tumblehome area is cherry, the rest of the canoe will be Atlantic white cedar.
Gaining some.
Status:
I may make a spring deadline yet.
Fitz.
I dunno why I deal with this
messy epoxy stuff, (makes leaded filler look like a cake walk), but it is working out okay.
This is "hybrid" kevlar/carbon fiber going on the inside. Now, if it could only generate its own solar power....:D
I'm a bit worried that this canoe might just be a tad bit too racy for Grandma...:eek:
Steam Bent Stem Strips
I decided to laminate the outer stems with ash strips. The strips are only 1/8 inch thick, but I didn't think I could coax them to take the shape of the stem without a little steam. Once they dry for awhile, I'll glue them up.
Getting There.
I gotta mount the seat in the bottom somehow and then do the sanding/varnish repeat process for the entire boat, but it is getting there. Launch just in time for Mother's Day??:cool:
I'm calling this one done. I may get a chance on Monday to give it a Test Paddle.
Nice! Really Nice. Very pretty boat. Let us know how it paddles and post a picture of it on the water.
Weight
Thanks Jim.
I forgot to mention, it is a little on the heavy side. With all the hardwood trim, brass, extra unnecessary epoxy this 12 footer weighs in at 30.6 pounds on the bathroom scale.
I wasn't and I'm not really concerned about weight, but I was thinking it may be closer to 25 pounds.
Fitz.
