The Old Town canoe with serial number 39093 is a 17 foot long, CS (Common Sense or middle) grade, HW (heavy water) model with red Western cedar planking, closed spruce gunwales, birch decks, birch thwarts, birch seats, spruce finish (outside) rails, and a keel. It was built between July, 1915 and January, 1916. The original exterior paint color was dark green. It shipped on April 7th, 1916 to Philadelphia, Penna. A scan showing this build record can be found by following the link at the attached thumbnail image below.
This scan and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at
http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See
http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and
http://store.wcha.org/WCHA-New-Membership.html to join.
It is also possible that you could have another number or manufacturer if this description doesn't match your canoe. Feel free to reply here if you have any other questions. Good luck,
