Hi Folks,
I'm in the process of restoring a 1924 Kennebec. When I received the canoe it had been through a prior restoration. So I'm not sure of it's original design. I have removed the fiberglass from the hull, stripped the interior and received some assistance with canvassing and filling the weave. My question centers on the stem. I could add a brass stem band to cover the overlap seam of the canvas. However, I'm worried about the level protection the stem band will provide. Or I could build an outer stem, splicing it into the keel, at which point I would add the brass stem band. I know this would provide all the protection I should need. But I'm not sure if the canoe had an outer stem when it was built. Any assistance will be appreciated. Thanks!
