I would make a suggestion that may save you some difficulties: If your hull is rockered at all, when you place the boat on the floor for scribing, I would place some sort of blocks under the extreme ends of the boat that ensure the integrity of the hulls shape, as if it was sitting in water. I made the mistake in scribing a line on my twenty foot EM White, on a flat floor, not thinking think the pressure on the boat sitting on its belly would cause the ends to droop toward the floor. So my waterline bulges in the middle of the boat.
the twenty footer I scribed and painted probably compound the problem since there is considerable pressure that far from center, and the boat weighs 110 pounds.
