fred capenos
Canoe Pilot
I just finished stripping a 16 ft Otca. The planking on this canoe is very tight, unlike the H W that I just completed. As tight as the planking is, a lot of stripper leaked through to the outside. I started thinking about the amount of stripper that must be trapped between the planks. then I removed a section of planking that was broken and saw all the stripper that had been blasted under the ribs from the hose water pressure.
I wonder if this residue could lie dormant and then be rejuvenated later when the canoe gets wet on the inside, causing vapors to penetrate the canvas and filler and attacking the paint. The question would be, do blisters occur on new boats that have never been exposed to stripper or any other caustic substance that could be trapped under the ribs?
Fred
Fred
