15' old town
The scanned Old Town records stop at 210999 so none of us have any newer information. Old Town stopped keeping detailed records in the late 1980s and yours is after that. They issued serial number 500,000 in 1995 and their millionth serial number was issued in 2003. You can also look for the hull identification number on the starboard stern that contains an embedded shipping date. Good luck,
My mistake, try 166846 not 7xxxxx.
This boat is much older than 1980.
Thanks,
Searay
The Old Town canoe with serial number 166846 is a 15 foot long, CS (Common Sense) grade, fifty pound model with thwarts in place of seats, and a keel. It was built between December, 1957 and January, 1958. The original exterior paint color was dark green. It shipped on April 30th, 1958 to Reidsville, North Carolina. A scan showing this build record can be found by following the link at the attached thumbnail image below.
This scan and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/wcha/ to learn more about the WCHA and http://www.wcha.org/join.php to join.
Thanks Benson,
Would you be able to post any catalog information for this model type?
I am considering perhaps fitting it with proper seats and would be interested in any discription of the seat that Old Town would have installed.
Searay
The page describing this model from the 1958 catalog is attached below. The specifications at http://www.wcha.org/catalogs/old-town/specific.gif may also be helpful. More information like this is available on the Old Town Canoe Company catalog CD. It is available at http://www.dragonflycanoe.com/cdrom.htm or http://woodencanoe.org/catalog/product_info.php?cPath=90_91&products_id=404 in the WCHA store.
The 1950s canoe seats used manufactured cane and are similar to many of the ones offered today. One difference is that most of the modern ones have rounded corners on the cane area while yours would have had square corners if you want to be really original. Good luck with your restoration,
Thanks again Benson.
I'll see if I weigh this boat and let you know if it tops 50lb without the seats and post a few phots as well.
Searay
Most of these weigh more than fifty pounds and I suspect that the difference in weight between a thwart and a seat is not significant. The catalog page indicated that yours was 58 pounds when new. I have one shown at http://forums.wcha.org/showthread.php?t=3968 and the current weight is actually 63 pounds according to my bathroom scale. Pictures are always welcome. Thanks,
Beson,
The build record does not list the type of wood for any of the components.
What would you assume they are on this 1958 50#?
Searay
50 Pounder
I restored a 1964 vintage one last summer. It had seats. I can't remember if I put No. 10 or 12 canvas on it (must be the leaded filler:eek:), but my bathroom scale indicated 59 lbs when finished.
My canoe was not an AA grade, but it had mahogany outwales. Spruce inwales and ash seats. My center thwart was missing, so I fabricated one from ash to go with the seats.
Fritz,
Is planking at this date always 5/32" red cedar and the ribs white cedar?
Do you find No 10 canvas too light for typical service use? I want to keep it light without sacrificing durability .
Planking
IIRC OT used thinner 1/8 inch thick planking and 1/4 inch thick ribs on the lightweights to cut down on weight. I had to replace much of the planking in the bottom of the canoe.
The more I think about it, I'm pretty sure I used No. 12 on this canoe. My uncle in law lives on a lake and it wasn't going to see hard use.
I think you will be fine with No. 10.
I finished restoration of a 1963 15' 50 lb model last winter. Like Fitz's, it also weighed 59 lbs with 12# canvas and external stems.
Nice looking boat Fritz.
This 50# is going to be the right one for my first restoration project. I assume the thinner planking and ribs are easier to work with. Most of it is in good shape but 50% of the bottom planking will need to be replaced.
Can you recommend a good source for this?
Planking
Searay:
Several of the vendor members on this site sell planking. My canoe had western red cedar planking. The local lumber yard has long lengths of clear WRC decking that I used to mill planking.
Fitz.
The specifications page from the 1958 catalog is attached below. It lists 1/4 inch white cedar ribs, 1/8 inch red cedar planking, spruce inwales, and mahogany outwales as Fitz mentioned. It always annoyed the people in the factory that the width of the saw kerf was larger than the planking on these canoes so more than half of the wood was lost when making planking. Good luck with your restoration.
