105747 16
The Old Town canoe with serial number 105747 is a 16 foot long, CS (common sense or middle) grade, HW (heavy water) model with red western cedar planking, open spruce gunwales, a keel, and outside stems. It was built between April and July, 1930. The original exterior paint color was white. It shipped on July 2nd, 1930 to Tobyhanna, Penna. A scan of this build record can be found by following the link at the attached thumbnail image below.
A scan showing this build record can be found by following the link at the thumbnail image attached below. This scan and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to join.
It is also possible that you could have another number or manufacturer if this description doesn't match the canoe. Feel free to reply here if you have any other questions. Good luck with the auction,
