Ron Bedard
I'm working on the restoration of a 1944 Old Town Guide 18, and the varnish needs more than sanding before new coats. I know how much work it would be to strip all that old varnish, and I hate that whole process. I also want to preserve that beautiful dark patina that really can't be duplicated.
I've done quite a bit of furniture restoring, and often use a product made by Homer Formby. It's a solvent that rubs into the finish with fine steel wool. The original varnish "re-activates", and dries again when you're satisfied that scratches and flaking are corrected. You can then sand and add more coats if desired.
This has worked really well, and I figured I'd pass it along.
Sorry if I'm reinventing the wheel.
Ron
Ron
