Old Town #92373 16
Can you confirm the length of this canoe and get some pictures of the numbers from each end to share here. I've checked this and several similar numbers but didn't find a double ended canoe that was 16 feet long. The scans showing these build records can be found by following the links at the attached thumbnail images below.
These scans and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/wcha/ to learn more about the WCHA and http://www.wcha.org/join.php to join.
Feel free to reply here if you have any other questions. Thanks,
