mast to boom?
David Satter
Wooden Canoe Maniac
Mast to boom rope connection lateen. Is there any special knot or specific lashing? Or should I use my own?. Thanks, Dave
Benson Gray
Canoe History Enthusiast
Staff member
Well, the boom on an Old Town lateen rig is usually held in place with a bronze jaw that is screwed to the boom as shown below. The screw heads are commonly covered with a twine wrap. See https://www.wcha.org/forums/index.php?threads/10672/ for some pictures. The halyard connects the yard (which is occasionally called the top boom since it is the same size as the bottom boom in a lateen rig) to the mast. This is frequently connected to a screw eye in the yard. I use a clove hitch around the yard if I want to retain the option to easily adjust the attachment point. Let me know if this doesn't answer you question or you want more details.
OP
OP
David Satter
David Satter
Wooden Canoe Maniac
index.php
this is the setup I have , On the one here in the shop has a strip of leather holding the two booms together, like a hinge. I was thinking of #11 holding the lower boom to the mast. just a lashing or knot?
