Info On Canoes
  • Thread starter Thread starter Unregistered
  • Start date Start date
U
Unregistered
Guest
Oldtowne Sailingmodel #118100 17 Second Canoe Hasno Builders Name On It #gn84713
Old Town 118100 is a 17' CS grade Otca built in 1936. No mention is made on the card about a sail rig, so this may have been added at a later date. More details on the card attached below.
Canoe GN84713 is a 16' Penn Yan Scout model. It is not possible to date it with the serial number but the GN code was in use 1948-1960.
These scans were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as described at http://www.wcha.org/catalogs/old-town/records/ in more detail. If you are not already a member, we hope that you will join or contribute to the WCHA so that services like this can continue. See http://www.wcha.org/wcha/ and http://www.wcha.org/join.html for more information.
