Another Mystery Canoe
mn2016
A friend of mine inherited a wooden canoe she would like me to try to sell for her.
There are no marking of any kind on this canoe.
Dimensions
Length 13'
Beam 38"
Depth 12"
I am hoping to determine an estimate of value based on the photos.
Also looking for an estimate of what it might cost to repair.
Any help would be greatly appreciated.
Thank you.
More Photos
More photos attached.
More photos
That's it for photos. Any help would be appreciated very much. Thanks.
It is exceptionally difficult to estimate the value of a canoe or the cost to repair it from photographs. The value of a restored wooden canoe like this is usually less that the price of a professional restoration. This one appears to have been modified or repaired at least once before. I don't recognize the builder. The information at http://forums.wcha.org/showthread.php?57 may help you value it and the estimates at http://www.smallboat-shop.com/Restoration Process.pdf may give you some idea of what might be required to repair it. An advertisement at http://wcha.org/pp-classifieds/ is probably the easiest way to find a good new home for this canoe. Good luck with the sale,
Thank you
Thank you Benson. Your response and suggested links have been very helpful. The search continues. I just may end up purchasing it myself. Have a great day.
Do need/want a short, wide canoe?
If you do, it might be worth a couple hundred, if you don't, it's worth less.
If what I see is what I think it is (C08.jpg) the biggest problem with the boat is that it appears to have come under siege from anobiid beetles (wood-borers) at some point. That could be a really serious issue depending upon how much damage they have done and whether or not they are still active in the boat. If there is fresh dust present do not bring that thing indoors! It is possible to treat them if they are still present but the extent of damage done will affect the value of the boat. I would try to get a good look at the stem to see if it also shows borer exit holes.
The rot on the rails appears to be fairly contained and a relatively easy repair, at least as depicted in the pictures. As Benson notes, repair estimates without the boat physically present are impossible so there may be other hidden issues lurking. At a minimum you are looking at repairing the rails (splicing in new pieces) and re-canvassing. Re-varnishing, repairing/replacing the seats should also be done and will add time and cost.
It is a stumpy little boat but these little canoes are actually nice to use for hunting small creeks or hauling decoys in and out of swamps etc.
Helps to know where its located. Looks like a Northland from Huntsville Ontario, and they were usually fiberglassed like that.
hard to say for sure though, could be built by any number of people. Maw used that seat hole pattern, like Rilco and some others.
