old town 16
2polebarns
please can you provide build sheet for a old town canoe ser.no. 154405 16 I have had this canoe since 1967 and it is in very good conditionalso have 2 original paddles.thanks
The Old Town canoe with serial number 154405 is 16 feet long, CS (common sense or standard) grade, Yankee model with red western cedar planking, open spruce gunwales, and equipped with a keel and either a floor rack or outside stems (the date stamp splits the line – can’t tell which it is). It was built in 1950-51 and was shipped on May 26, 1952 to Detroit , Michigan. Its original exterior finish was dark green enamel. A scan of this build record can be found by following the link behind the thumbnail image attached below.
A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to join.
Greg
