I suspect that I've done exactly what many others have done when scarfing a piece onto an outwale, or filling in a deep gouge to a deck: mix some epoxy resin, paint it onto the surface, mix fine wood dust (maybe sander dust) into the remaining epoxy and make it very thick, then spatula that onto the joint or into the hole. My observation is that no matter the color of the wood dust used, the cured epoxy always looks very dark, and visibly stands out in an undesirable way on a light wood. Is there a technique that will give both a strong glue joint and a light color? Tom McCloud
