Which tool
Howard Caplan
Wooden Canoe Maniac
As I expand my work shop I am curious as to which tool both power and hand, is the most used/important in your shop.
howard
That depends entirely on what you plan to do in your shop, and how you plan to do it, including how loud you want to be while you do it. If you'll be ripping a lot of lumber, you may want a sizable table saw... or maybe a radial arm saw.. but then some people prefer a band saw for that... for millenia, that was done with hand saws. There are more ways to skin a cat than there are cats.
When I did my cabinetshop apprenticeship, my mentor taught me that the most expensive tool you'll ever buy is the cheapest one on the shelf. Unfortunately, I've had to re-learn that more times than I care to admit. Generally speaking, you'll get what you pay for.
And the older I get, the more I appreciate hand tools...
As Paul says it "depends entirely on what you plan to do in your shop". For instance if I am replacing inwale ends, a deck tip and a stem end I use the bandsaw to cut the pieces and then the bench sander to help shape and finish the pieces. The bench sander allows you to hold small, uneven peices against the paper without the worry of taking your fingers down to the first knuckle as might happen with the larger floor model. And you can have it at hand pretty easily so you don't have to keep walking away from your work. I've found the bench sander to be a real asset and they're only about $100.
So that's one example - hope it helps.
What Paul said... our recommendations might be quite different if you are planning to build cedarstrip vs. lapstrake canoes, or make paddles, or do cabinetry. A lot also depends on your available space (a tablesaw with extension wings and outfeed tables takes a shyte-load of space).
Because there are lots of different ways to skin a canoe, it would be easy to simply make a list of the tools I use most often (and I will if folks want me to), but my way may not work for you. One thing I will highly recommend is to give a lot of thought to a permanant sharpening station. You can't work effectively if you don't keep your tools sharp, and you won't sharpen them as needed unless the sharpening stuff is out and ready to go. In many ways, this is the most important part of the shop...
You guys sound like politicians not wanting to alienate the shop tool vote.:)
Band saw came up twice.
OK, band saw or table saw first - which is the discussion I am having with myself at this moment.
As far as useage goes, I suspect there is a tool we all go back to whatever the specific project may be.
howard
Dan,
We posted at the same time. A sharpenning station is in my plans. But I know little about what is needed. Can you elaborate on what would make a good, versatile sharpenning station?
And, I would love to see a list of the tools you use most often.
howard
Bandsaw, no question. You can do most everything on the bandsaw (occasionally accompanied by a handsaw), that you can do on the tablesaw, except dado and use a molding head (a scary proposition). Plus, you can do all the curvy cuts you can't do on the tablesaw. And, the footprint required by the bandsaw is significantly less.
Yep, the benches are cluttered with them and there are several toolboxes with these in them as well.
my thought
Most folks, including me, start out with the table saw first. Then the band saw joins the team. Most band saws are 14" for the home shop. so there is a limit to how wide a piece can fit on the frame side. Whereas the table saw is limited only by the width of the building. I like my band saw tho. Both are useful.
The permanent sharpening station is an excellent suggestion. There are a lot of rigs out there, and which setup you choose will depend a lot on what you're comfortable with. Take a look at Leonard Lee's book "Sharpening" for some great info. He may get too technical for some folks, but I appreciate knowing the WHY behind everything.
And I'll put in my vote for a good set of spokeshaves. I do more paddle-making than canoe-building/restoring, so that has a huge impact on that call. They're not capable of destroying piecework in a heartbeat, like power saws & sanders. (It just takes longer to destroy things).
Howard,
Like others have said, it depends on what you plan to do.
What hasn't been said, is, it really doesn't matter, cause you won't/can't just buy 1 tool, you will be buying others.
That said, my list;
table saw
disk/belt sander combo
drill press
band saw
planer
What else hasn't been said, is don't go looking for new tools, find old used ones, they are much cheaper and often with a little maintenence, better then what you can buy today.
For help here go to the OWWM.com/.org sites for info about old machines.
Becareful though, the old machines are just as addictive as old canoes.
who lately has been collecting old tools instead of old canoes.
Maybe more useful than this would be to prepare a list of recommended tools for a canoe shop, breaking it down to basics/essentials, then additions appropriate to strip building, w/c paddle making, etc. I'll get started, I expect some comments, and when all is said and done, we ca nturn it into a web page for the Building and Repairs section of the site... sound good?
Dan, and all
Boy do I look forward to seeing your lists. Just what I need - incentive to by more tools-- yeah right!
Denis :D
Dan - is your list in order of importance/actual usage?
you guys are great!
Here is what I have, so far:
At a rummage sale bought a very old Craftsman Radial Arm saw and a newer short bed Delta 6" jointer - the radial arm scares me a bit and I still have to true up the table and backstop. I'm getting used to the jointer and have used it for several non-canoe projects.
Found a 13" planer on-line at ebay and got a great price. Very handy.
Bought a $99.00 belt/disc sander and because I don't have a router used it to shape an outwhale piece for my kevlar. I'm still not sure if the original is a router cut or not.
Just picked up a Japanese saw with two blades. Very nice with it's narrow kerf and very clean cut. Used it to cut the rotted ends from the gunwales of the same kevlar.
Have a block plane and bench plane, which both need tuning up. Read about a process to true the base using very flat glass and powdered grit. I'm going to try that. Bought a rabbitt plane to lip the new inwale pieces on the kev. Getting used to using it still.
I want a table saw but space and money are steering me to the band saw - which was the real reason for my original post.
Give me more about your shops.
Howard
Dan - this does sound good!
howard
i think these are the most used powertools for my canoes building. not in any order but they seem essenial for enjoyable work.
bandsaw (20" has been a great improvement)
tablesaw
surface planer
ro sander
belt sander
hand power planer
drill
visa(or mastercard)
OK here is first pass, off the top of my head in five minutes, and loosely organized. As Max says, let the Rumpus begin!
Additions and comments welcome!
Basic Tools:
Stationary Power Tools:
Bandsaw - can do almost everything the tablesaw can do, plus does the curvy cuts as well. generally safer than the tablesaw
Tablesaw - will rip stock much faster than the bandsaw. Takes more floor space than the bandsaw. Essential for strip canoe builders and production canvas canoe builders.
(note, most folks end up with both of the above)
Dust Collector
Drill Press
Surface Planer
Hand Power Tools
Cordless Drill (I am partial to the Milwaukee 1/2" 14.4V)
Belt Sander
palm sander
jig saw
Hand Tools
Saws: Japanese Ryoba saw is a great rip/crosscut compromise
Block Planes:
Low-angle, such as Stanley 60-1/2. You won't regret buying a Lie-Nielsen
rabbet block plane, vintage only made by Sargent and are for collectors. Buy a Lie-Nielsen.
Bench Planes:
Smoother (e.g. Stanley #3 or #4)
Jack (e.g. Stanley #5)
Jointer (e.g. Stanley #7)
Spokeshaves
Stanley #151
Chisels
Basic set of bench chisels 1/4" - 1"
Measuring:
Combination Squares - 4" and 12" (don't settle for less than Starrett or Brown and Sharpe)
12' Stanley Powerlock Tape Measure
dressmaker's cloth measuring tape (great for measuring girth for replacement ribs)
folding rule with extension
assortment of calipers and dividers
bevel gage (Stanley 18 best as locking knob away from business end, Lee Valley makes some nice small ones)
compass
screwdrivers (assortment)
rasps and files
clamps (did we say you could have too many, no we did not!)
Sharpening
set of oil stones or water stones
bench grinder
Ready to Expand?
Chop Saw or Radial Arm Saw (I find RAS difficult to keep in alignment)
Stationary Belt sander (for shaping stock and occasional sharpening duty)
Jointer (I don't have one)
Drum sander (for sanding planking, rib stock)
Hand Power Tools
Laminate Trimmer or Router
Hand Tools
Saws:
Block Planes
Skew Rabbet Planes (L and R set from L-N)
Bench Planes
Stanley 4-1/2, 5-1/2
Spokeshaves
selection of low-angle wooden spokeshaves (best new ones are Dave's Shaves)
Chisels
2" paring chisel
selection of gouges
Measuring:
dial calipers
Brace w/ screwdriver bits
Awl(s)
drill bits (assortment as needed, brad point (the expensive ones from Lee Valley) for fine work, forstner bits for large work (essential for replacing Morris pocket inwales)
Advanced Stuff:
Chisels:
30 or 35 mm number 3 sweep Swiss Made Gouge (better than a chisel for trimming flush)
Sharpening:
Tormek grinder
steam box (essential for wood canvas and lapstrake, optional for strip building, probably not necessary for most stitch and glue)
For Strip Building:
Router mounted in table
bead and cove router bits
For Canvas Canoe Building:
clinching iron
canvas stretcher (webbing stretcher, artists pliers or sheet metal vice grips)
come-along
cobbler's hammer (minimizes blossoms when clinching tacks)
staple gun
planking gage (see Stelmock and Thurlow book)
router in table with round-over bit (for rounding over rib edges)
For Lapstrake Canoe Building:
rabbet plane (for cutting gains)
clinching irons or rivetting tools
lap clamps
For Paddle Making:
Axe (optional)
drawknife
angle grinder with abrasive discs
For Seat Repair/caning
1/8 morticing chisel or special-made chisel (for cleaning spline groove)
small router plane (like Stanley 271, for cleaning spline groove)
cool tool
couldnt begin the rumpus this week without a sharp pencil. Dan, who is Max?
wild things
nah, guess not. Bet i will soon though with 2 and a 3rd on they way. not totally deprived tho, I did know what ooblek was.:cool:
