#1
I would be interested in feedback from anyone who has used this filler recipe from the Wooden Canoe #16. 43 oz boiled linseed oil, 21 oz mineral spirits, 34 oz enamel paint**, 2 oz japan drier, 6 1/4 lb 300 grit silica, 2 oz spar varnish.
**Is this any enamel paint, any color? Is this enough filler for a 16 ft. (St Louis meramek) canoe? Thanks! |
#2
I've used this recipe, seems to work fine. It is essentially Old Town's unleaded recipe. It is more than enough to fill a 16' canoe (you'll probably have left-overs, so get an empty metal paint can from the hardware to store the extra.
There is no mildicide activity, due to the absence of the white lead. So use treated canvas or add a mildicide (or both). There is no magic to the color of the paint you use. Some like to tint the filler close to the final paint color so scratches are less obvious. Others like to contrast with the final paint color so that deep scratches are easily seen and repaired. If you plan to paint your canoe red, then gray is the best color to use for your filler, as gray primer under red paint is essential. Make sure you allow the filler to cure fully before finishing.
__________________
Dan Miller WCHA Webmaster Emeritus Curator, Antique Boat Museum (http://www.abm.org) Dragonfly Canoe Works (on sabbatical) (http://dragonflycanoe.com) Clayton, NY |
#3
Where can one find the japan drier and silica?
Frank
__________________
Frank WCHA #8328 |
#4
This is basically the filler that I use. I've made a few adjustments, but pretty minor.
I substitute clear wood preservative for the paint thinner. The one that I use has zinc napthanate as an active ingredient. I leave out that tiny bit of varnish. I can't see what essential quality that it is contributing to the mix. I use beer cups for meauring. Check the volume of the cup, but for mine it works out to 3 parts boiled linseed oil, 2 parts enamel, 1.5 parts thinner. I use the same enamel that I use for painting the canoe, but you don't need to use really high end paint! I'm in the camp that likes to have a similar colour of filler as finish paint. You can get Japan Drier from good paint stores, I've even seen it in Home Despot. If the clerk serving you doesn't know what it is, you're in the wrong store... Silica you can get from a ceramic/pottery supply company in your neighbourhood. Ask a potter if you need help finding it. |
#5
Here's an online source for the silica - http://www.standardceramic.com/ - I've never used them, and it looks like you'll need to order 100 pounds. Best to find your local pottery source, then you only have to buy 50 pounds and can avoid shipping...
I used to substitute the preservative for the thinner too, but it is harder and harder (impossible?) to find oil-based preservatives in the states anymore. Can't get zinc napthenate here either. You can still get copper napthenate, but pretty much only in 5 gallon pails from industrial supply. I now use the little packets of mildicide that are in the paint section of the hardware.
__________________
#6
when you say "clear wood preservative" do you mean a product like Thompson's water seal?
any pottery supply will have silica but most call it "flint" it's very cheep.
__________________
You're just jealous because the voices only talk to me |
#7
Quote:
Thanks, Dan. Just curious as to why gray primer under red is essential? Is there a chemical/physical reason? Or are you a Buckeye fan? |
#8
Quote:
__________________
#9
Wasn't there an old B movie, a WW II comedy of navy nurses 'rescued' by a leaky old sub that get's repair and painted w/ a mix of red oxide primer & white...a pink submarine?
__________________
1958 Otca 16; From Camp Hagan, Shawnee on the Delaware...Dad got it from the caretaker in 1974 for $45.00.WCHA Member No 7349 |
#10
Bob,
I don't know Thompson's products that well, so don't know what they really are or can do for you (my limited experience with Water Seal has resulted in a nearly full can remaining unused in the basement for years. Didn't seem to work all that well for me...) If you are mixing with filler, you basically want something poisonous in an oil-based carrier - like the zinc napthenate Douglas mentioned, or the copper napthenate that was in the old clear Cuprinol (clear Cuprinol is now water based). I've pre-treated canvas with water-based preservative prior to filling. I make sure there are no silicones (which often added as water repellents) and that the manufacturer clearly states the preservative can be painted. It needs to dry thoroughly before filling. Since one of the fillers I use regularly is water-based, this is less an issue. As with all things of this nature, you should test all the various goops you use to ensure compatibility.
__________________
| Thread Tools | |
| Display Modes | |
