I have recently bought an old all-wood canoe (maybe 30 year old?) to be able to take the whole family out. I have previously built using strip-teqnicue and skin-on-frame, but this construction is new to me (all wood, non canvas). My question is: I have absolutely no way to store it inside or in a garage. My thinking is to store it outside in the backyard a bit up from the ground with a little roof built on top. I live in Sweden and it can be down to -20 degrees Celsius on the winters and as warm as +30 degrees Celsius in summertime here. Do you think the canoe can be damaged stored like this? I will care for it regularly and varnish it every year. I think most wooden boats are stored outside like this? Another question: there are thin strips of metal under the hull to prevent scratches. I can understand the idea with these, but it has come loose at some places and I think water can get inside the wood. My solution would be to remove the metal and instead seal with epoxy. And if to deep scratches patch with new epoxy/varnish - what do you think of this? Things I should do and shouldn´t do? Very thanksful for responses to this! Best Bertil
